旧 2016-01-13, 15:45     #1
Shendu360 Shendu360 当前离线
级别:4 | 在线时长:41小时 | 升级还需:4小时
Uid: 342589
注册日期: 2013-05-01, 07:18
声望: 10 Shendu360 向着好的方向发展
Uid: 342589
默认 求助施乐5065出纸口卡纸,报代码077-109
我的施乐5065经常在出纸口卡纸,报代码077-109,都烦透了,菜鸟求助大师,应该怎么办,谢谢。
文件类型: jpg kz.jpg (942.4 KB, 14 次查看)
Shendu360 当前离线
旧 2016-01-13, 17:31   只看该作者   #2
balenofeng 的头像
balenofeng balenofeng 当前离线
Uid: 80820
注册日期: 2008-12-15, 12:18
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
声望: 10 balenofeng 向着好的方向发展
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
作者: Shendu360 查看帖子
可能是翻转那个爪子没调好或者是有胶等异物挡住了纸
077-109 IOT Exit Sensor On Jam Straight
Bsd-on:CH10.15
The IOT Exit Sensor does not turn ON within the specified time during paper transport in the IOT Exit unit. (Straight output)
Initial-action
Check the size of the paper in the tray.
Turn the power OFF then ON.
Remove the foreign substances on the paper transport path.
Procedure
Check the Transport Roll for wear, deterioration and paper dust.
Is the Transport Roll in proper condition without wear, deterioration or paper dust?
Yes No
Replace the worn or deteriorated Transport Roll.
Check for foreign substances, distortion and paper dust in the paper transport path.
Is the paper transport path in proper condition without foreign substances, distortion or paper dust?
Yes No
Remove the foreign substances and paper dust. Correct the distortion.
Execute DC330 [077-107 IOT Exit Sensor]. Move the actuator of the IOT Exit Sensor (PL 10.4) with paper.
Does the display change?
Yes No
Go to GP-034 IOT Exit Sensor Check Out FIP.
Execute DC330 [077-011 Invert Gate In].
Is there any operation noise from the Invert Gate Solenoid (PL 10.5)?
Yes No
Go to GP-032 Invert Gate Solenoid Check Out FIP.
Replace the MCU PWB (PL 11.1).
balenofeng 当前离线
旧 2016-01-13, 17:41   只看该作者   #3
Uid: 342589
Uid: 342589
不好意思,翻转爪子是哪个,外侧门纸路打开看过了没胶。卡的纸可以看到有一个口子。
Shendu360 当前离线
所有时间均为 +8, 现在的时间是 2025-12-03 05:12.
